HOOVER - R POWER PATH PRO CARPET CLEANERS
The Hoover(R) Power Path Pro carpet cleaner combines two powerful scrubbing systems to bring you a whole new level of deep clean. It features both a rotating brushroll and our SpinScrub(R) Technology so you can lift and remove tough stains. The removable 13 in. Dual V(R) Nozzle and 1 gallon clean water tank let you cover large areas with less hassle. Use the 8 ft. Hose and Upholstery Tool to clean furniture and stairs then attach the Hard Floor Squeegee to get to sealed hard wood, tile and more. Heated Cleaning and Dual Tank Technology provide a fast dry time and an easy clean-up so you can get back on your floors in no time. Model FH51102.
Price: 219.99
